[SOLVED] HiDPI Theme/Version?
Post here those questions, bug reports and suggestions for SoftMaker Office 2016 for Linux that do not fit in any of the application-specific subforums.
NaEaP
Post by NaEaP » Tue Oct 31, 2017 10:54 am
Hi there!
I've recently purchased Softmaker Office 2016 Windows & Linux and ran into a problem with the HiDPI display on my laptop.
Is there a possibilty to have a HiDPI GUI or do I have to find a scaling solution on the system level?
Thanks in advance!
EDIT: Found the option
Tools - Options - Appearance - User Interface Size
Works like a charm :D
Re: HiDPI Theme/Version?
Post by martin-k » Tue Oct 31, 2017 10:57 am
Tools > Options > Set user interface size
When we tried to determine the dpi to scale the UI automatically, we found that some distributions return bogus values. That's why we let the users do it manually-
NaEaP
Re: [SOLVED] HiDPI Theme/Version?
Post by NaEaP » Tue Oct 31, 2017 10:58 am
Thanks for the fast answer :)
AZgl1800
Post by AZgl1800 » Mon Jan 15, 2018 2:14 am
I accidentally set the theme font size so large, that I cannot see the bottom half of the options screens.
how can I get the Defaults restore for all of FreeOffice?
Post by martin-k » Tue Jan 16, 2018 2:48 pm
Delete tm16config.ini, pm16config.ini or pr16config.ini (or the similar files for FreeOffice).
Return to “SoftMaker Office 2016 for Linux (General)”
