Softmaker 2016 tgz install on Mandriva 2010.2
General questions and answers about SoftMaker Office 2016 for Linux. Don't post application-specific questions here, but in the appropriate subforum.
JohnI
Post by JohnI » Thu Nov 24, 2016 5:02 pm
I bought the new Softmaker Office for Linux and installed it on my Mandriva 2010.2 workstation. Softmaker Office 2010 is already installed here and is crucial for riunning my business so it can't be dumped until the new version is working.
The RPM based download failed so I used the .tgz file. It runs to completion and says installed successfully but when I try to start any one of the components it fails. Here are the error messages:
[john@wkstn01 ~]$ textmaker16
/usr/softmaker-2016/textmaker: error while loading shared libraries:
libidn.so.11: cannot open shared object file: No such file or directory
[john@wkstn01 ~]$ presentations16
presentations: tnl/t_draw.c:406: _tnl_draw_prims: Assertion `ctx->NewState
== 0x0' failed.
/usr/bin/presentations16: line 5: 24211 Aborted
/usr/softmaker-2016/presentations "$@"
[john@wkstn01 ~]$ planmaker16
planmaker: tnl/t_draw.c:406: _tnl_draw_prims: Assertion `ctx->NewState ==
0x0' failed.
/usr/bin/planmaker16: line 3: 24312 Aborted
/usr/softmaker-2016/planmaker "$@"
[john@wkstn01 ~]$
The installation messages are:
[john@wkstn01 soft2016]$ su
Password:
[root@wkstn01 soft2016]# ./installsmoffice
This script will install SoftMaker Office 2016.
Do you want to continue (y/n)? [y] y
It seems that you have root permissions.
If you have root permissions, you can install the application
for all users on this machine.
If you do not have root permissions or want SoftMaker Office 2016
only to be used by the current user, you can install it locally.
Do you want to install SoftMaker Office 2016 only for the current user? (y/n)
[n] n
In which directory do you want to install the applications
(press Return to accept the existing value)?
[/usr/share/office2016]
/usr/softmaker-2016
This directory exists already.
Do you want to choose a different directory? (y/n) [n] n
In which directory do you want to install the launch scripts
[/usr/bin]
The applications will be installed to
/usr/softmaker-2016
The launch scripts will be installed to
/usr/bin
Installing SoftMaker Office 2016 for all users.
Unarchiving /tmp/soft2016/office.tgz
Copying libraries...
Using existing xdg-utils
which: no notify-send in
(/sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin:/usr/local/bin:/usr/local/sbin:/usr/lib/qt4/bin)
Create MIME
Adding document icons. This may take a few minutes...
Updating theme contrastlarge
Updating theme crystalsvg
Updating theme default
Updating theme default.kde4
Updating theme favicons
Updating theme gnome
Updating theme handhelds
Updating theme hicolor
Updating theme Human
Updating theme large
Updating theme locolor
Updating theme mini
Updating theme mono
Updating theme oxygen
Updating theme Oxygen_Black
Updating theme Oxygen_Black_Big
Updating theme Oxygen_Blue
Updating theme Oxygen_Blue_Big
Updating theme Oxygen_White
Updating theme Oxygen_White_Big
Updating theme Oxygen_Yellow
Updating theme Oxygen_Yellow_Big
Updating theme Oxygen_Zion
Updating theme Oxygen_Zion_Big
Updating theme redglass
Updating theme whiteglass
Updating theme wonderland
Registering MIME types...
Installing for user(s) john
Cleaning the cache from folder: /var/tmp/kdecache-john/*
Adding icons to the menu...
Adding icons to the desktop...
mkdir: cannot create directory `/home/john/SoftMaker': File exists
chown: invalid user: `xguest.xguest'
su: user xguest does not exist
SoftMaker Office 2016 has been successfully installed.
Just type 'textmaker16', 'planmaker16' or 'presentations16'
to start the applications.
You can find all SoftMaker Office 2016 applications in the Office menu group.
If you want to uninstall SoftMaker Office 2016 at a later time,
just run the command:
/usr/bin/uninstallsmoffice16
Press Return to exit.
The missing library shown in the error messages on startupo DOES exist as
/usr/lib64/libidn.so.11 (/usr/lib64/libidn.so.11.6.1)
How do I proceed to resolve this?
Regards,
John
Re: Softmaker 2016 tgz install on Mandriva 2010.2
Post by martin-k » Thu Nov 24, 2016 5:14 pm
JohnI wrote:The missing library shown in the error messages on startupo DOES exist as
You need to install the 32-bit version of this library. SoftMaker Office 2016 for Linux (like all before) is a 32-bit application suite.
JohnI
Post by JohnI » Mon Nov 28, 2016 4:29 pm
Which does raise the question of why only 32 bit versions are available when almost all workstations for the last 10 years have been 64 bit!
That said, a search of the Internet does not reveal a 32 bit version of this library for my distro and starting the other components under strace shows MANY missing libraries that do not exist as 64-bit libraries either on my system.
Since I have a real job here and it isn't workstation management, I guess the question is where to write to get a refund? To bad really, I would have liked to have some of the upgrades available.
Regards,
John
Post by sven-l » Wed Nov 30, 2016 8:56 am
JohnI wrote:Which does raise the question of why only 32 bit versions are available when almost all workstations for the last 10 years have been 64 bit!
We are working on a 64 bit version but there is no release date yet.
Return to “SoftMaker Office 2016 for Linux (General)”
