Using .tgz package for installation
Post here those questions, bug reports and suggestions for SoftMaker Office 2016 for Linux that do not fit in any of the application-specific subforums.
GeroldBr
Post by GeroldBr » Wed Jul 13, 2016 7:53 pm
I tried to install Softmaker Office 2016 on Salix 14.2 (a Slackware derivative) using the .tgz package. I've extracted the archive and changed into the directory (named 'softmaker-office-2016-757). After starting 'installsmoffice' I answered a couple of questions and then the installation was stopped with this message: "./office.tgz not found. Installation aborted." Well, the file 'office.tgz' was available within the same directory.
What's wrong?
Re: Using .tgz package for installation
Post by sven-l » Thu Jul 14, 2016 10:21 am
Have you started the installation with ./installsmoffice (with ./) and with root permissions?
GeroldBr
Post by GeroldBr » Thu Jul 14, 2016 12:29 pm
Yes, I started the installation with ./installsmoffice (with ./) and both as user and with root permissions.
Post by sven-l » Fri Jul 15, 2016 7:57 am
I will check that and inform our developers. Thank you!
As a workaround you may use one of the Linux distributions we tested:
http://www.softmaker.com/en/tips-linux
Return to “SoftMaker Office 2016 for Linux (General)”
