Applications won't start after installing rev. 752 service pack
General questions and answers about SoftMaker Office 2016 for Linux. Don't post application-specific questions here, but in the appropriate subforum.
hcastill
Post by hcastill » Mon May 09, 2016 2:57 pm
Hi all,
I'm using SoftMaker Office Standard 2016 on Ubuntu Mate 16.04 64-bit, rev. 749. When I installed the service pack - rev. 752, the applications stopped working. They didn't start when launched (the process of the program starts running but then quits silently). Uninstalling and reverting to rev. 749 solved the problem.
After investigating a little, it seems to be related to change 33932: "The applications no longer use SDL, but make straight OpenGL calls. This solves problems with some video drivers and keyboard configurations. The applications react again to xmodmap", but I don't know how to fix or circumvent the issue. I wouldn't like to be stuck in rev. 749 while new features and fixes appear in new revisions.
Thanks for any help
JohnbCallander
Re: Applications won't start after installing rev. 752 service pack
Post by JohnbCallander » Tue May 10, 2016 10:50 pm
See my post on 16.04 it might fix your problem as I think it has to do with 16.04 rather than SoftMaker Office.
hcastill
Post by hcastill » Wed May 11, 2016 10:30 am
The problem seems to be more on the graphics side, since I don't use the Software app to install .deb files. I use GDebi and the command line and all apps install with no issues (Google Chrome, Nylas N1 and SoftMaker Office 2016 rev. 749, for instance).
Thank you, anyway. I'll keep trying.
JohnbCallander
Post by JohnbCallander » Wed May 18, 2016 8:46 pm
Thanks for the thanks and I will look to see how you get on.
bkurt782
Post by bkurt782 » Wed May 25, 2016 2:47 pm
I am having a similar option on Fedora 23 after installing the 752 service pack. None of the applications will launch now. Instead I get small dialog box that says: Make sure that the resource file exists. If it does, try setting the SMPATH variable. Prior to upgrading to the 752 service pack for linux everything was working just fine. I have a screen shot of the dialog window I see.
Post by martin-k » Wed May 25, 2016 2:52 pm
Uninstall the old RPM, then install the new one. Does that help?
bkurt782
Post by bkurt782 » Wed May 25, 2016 3:13 pm
I've never actually had removing and re-installing a rpm package fix something before, but it indeed did the trick. There must be something in the scriptlets to make that happen. Is it best practice to always remove the rpm and then install the new version rather than doing an upgrade? Thanks for the help.
Post by martin-k » Wed May 25, 2016 3:28 pm
Normally this should not be necessary. We made a change for openSUSE (because of a bug in their distribution), and this now backfires on other distributions. We have implemented a different approach for future service packs.
bkurt782
Post by bkurt782 » Wed May 25, 2016 5:22 pm
Sounds good. Thank you for the information.
attilas
Post by attilas » Thu Jun 09, 2016 10:19 pm
martin-k wrote:We made a change for openSUSE (because of a bug in their distribution), and this now backfires on other distributions.
I had the same problem describe by bkurt782 with OpenSUSE Tumbleweed :D
asterixxer
Post by asterixxer » Fri Jul 08, 2016 3:31 pm
I had the same Problems on suse Leap.
After deleting the rpm and reinstalling, everything works fine...
Return to “SoftMaker Office 2016 for Linux (General)”
