Control key shortcuts not recognized
General questions and answers about SoftMaker Office 2016 for Linux. Don't post application-specific questions here, but in the appropriate subforum.
kcoady
Post by kcoady » Tue Jan 12, 2016 9:16 pm
Hi. I have SoftMaker Office 2016 749.1207 installed on Linux Mint 17.2 (Rafaela). No shortcuts involving the control key appear to work in PlanMaker or TextMaker. Ctrl-S doesn't save. Ctrl-C doesn't copy. Ctrl-V doesn't paste.
Alt-shortcuts work.
I'm not having any trouble with the control key in any other application.
Re: Control key shortcuts not recognized
Post by sven-l » Wed Jan 13, 2016 3:29 pm
I also use Linux Mint 17.2 with SoftMaker Office 2016 rev.749 and CTRL+C, CTRL+V and CTRL+S work properly. Which revision (Help=>Abpout) are you using? Are you copying content from inside SoftMaker programs or from another program like a web browser?
kcoady
Post by kcoady » Wed Jan 13, 2016 8:07 pm
It's rev 749.1207. And (after fiddling with a few things, seeing that it works on your setup) I found the problem.
On my system, if System Settings: Mouse and Touchpad: Mouse: Show position of pointer when control key is pressed is set, Softmaker programs don't see the control key press. If it's unset, they do, and everything works normally.
I presume this isn't the desired behavior, since it's not useful and every other program I've tried does register the control key when that option is set.
Post by sven-l » Fri Jan 15, 2016 10:47 am
I can see the issue and will inform the developers. Thank you!
Post by sven-l » Fri Feb 12, 2016 9:20 am
The problem has been solved and should not occur anymore with the next service pack.
kcoady
Post by kcoady » Fri Feb 12, 2016 9:41 am
Excellent!
Tom123
Post by Tom123 » Fri Nov 23, 2018 9:07 pm
Dear All,
I just purchased and installed Softmaker 2016 under Linux Mint 18.3
SoftMaker TextMaker System Information
Revision: 749
Linux distribution detection results: [3] ; LinuxMint ; 18.3
... and ran into the same shortcut problem reported earlier by kcoady :( .
Hoping for a corresponding service pack for Linux I had a look under https://www.softmaker.de/servicepacks-alt ... and drew a blank :( .
Where do I find a service pack for Softmaker 2016 Revision 749 for Linux?
Thanks & Regards
Tom
Post by sven-l » Wed Nov 28, 2018 9:43 am
Please download the Office version again using the download link in the e-mail with the license key you received after purchasing the Office. The download links now refer to the most recent version.
Tom123
Post by Tom123 » Sun Jan 13, 2019 4:15 pm
Thanks for your answer and sorry for my late reply.
Actually, I found the update I was looking for in the Help menu under "Help -> Check for Updates".
After the update to revision 765 the shortcuts work correctly.
Regards
Tom
Return to “SoftMaker Office 2016 for Linux (General)”
