Cell contents
Post your questions, bug reports and suggestions here for BasicMaker 2016 for Windows.
SteveF48
Cell contents
Post by SteveF48 » Tue Aug 02, 2016 5:41 pm
Does Basicmaker treat all cell values as strings?
This statement concatenates the values in the two cells addded:
workRange.Cells(i, 11).Value = workRange.Cells(i, 11).Value + workRange.cells(c, 2).Value
i.e. 0 + 25 = 25, but 25 + 50 = 2550
The funny thing is that larger values are shown as e.g.5.02525E+015
I guess that I have to convert the cell contents to integers before adding them, even though the cells are formatted as numbers in PlanMaker
Thanks in advance,
Steve
SteveF48
Re: Cell contents
Post by SteveF48 » Tue Aug 02, 2016 6:06 pm
Yes it seems that all cell values have to be converted to numbers before being used for arithmetic, so + is identical to & it concatenates strings.
The script now works as expected
Thanks in advance,
Steve
Re: Cell contents
Post by martin-k » Wed Aug 03, 2016 9:00 am
The type depends on how you declare the variables that receive the contents. Example:
Code: Select all
sub test
	dim pm as object
	dim n as integer ' an integer, VarType will return 2 (integer)
	dim v ' a variant, VarType will return 8 (string)
	set pm = CreateObject("PlanMaker.Application")
	pm.Activate
	pm.Visible = True
	pm.Workbooks.Add
	pm.ActiveSheet.Range("A1").Value = 42
	n = pm.ActiveSheet.Range("A1").Value
	print n, VarType(n) ' this way you retrieve to an integer variable, result is an integer
	v = pm.ActiveSheet.Range("A1").Value
	print v, VarType(v) ' this way you retrieve to a variant, result is a string
end sub
SteveF48
Re: Cell contents
Post by SteveF48 » Wed Aug 03, 2016 3:29 pm
I'm not using variables, so I'll have to remember to cast the cell's value to the correct data, if not string.
Thanks in advance,
Steve
Return to “BasicMaker 2016 for Windows”
