Using built-in dialogs
Post your questions, bug reports and suggestions here for BasicMaker 2016 for Windows.
XL-Dennis
Post by XL-Dennis » Tue Jun 09, 2015 11:52 am
Hello,
Is it possible to use the built-in dialogs in customized solutions?
If yes, can You please provide me with an exampel?
Kind regards,
Dennis
Re: Using built-in dialogs
Post by sven-l » Fri Jun 12, 2015 10:14 am
Did you mean Tools=>Customise? Sorry, but I do not understand what exactly you mean.
XL-Dennis
Post by XL-Dennis » Mon Jun 15, 2015 1:44 pm
For instance, I want to open the Save Dialog via BasicMaker.
Kind regards,
Dennis
Post by sven-l » Fri Jun 19, 2015 8:55 am
You cannot repurpose the file dialogs in SoftMaker Office for your own scripts; they are always wired with functions such as Open or Save As.
But if you google for "wsh file dialog", you will find solutions how to use the Windows file dialog in your own scripts.
XL-Dennis
Post by XL-Dennis » Mon Jun 22, 2015 7:53 pm
Thanks Sven :D
Kind regards,
Dennis
Return to “BasicMaker 2016 for Windows”
