Code error when trying to import EML files
Post your questions, bug reports and suggestions here for Thunderbird for Windows.
keithvenn
Post by keithvenn » Thu Jun 29, 2017 6:56 pm
I have just bought two licenses for Office Standard 2016 and installed on one PC.
When I start Thunderbird and click on the Tools option to import eml files, I get a message pop-up that says "TypeError: Stm.getColumnDecltype is not a function".
I have also discovered that the installation process REMOVES emClient, without asking permission, and I cannot find any .eml files on the drive.
Can someone confirm that the installation process has worked as intended, and tell me what has happened to the .eml files please? I assume this is why I received the error message quoted above.
Re: Code error when trying to import EML files
Post by martin-k » Thu Jun 29, 2017 7:01 pm
Several things:
1. When you install SoftMaker Office 2016, it suggests (but doesn't force you) to uninstall SoftMaker Office 2012. Doing so will also remove eM Client. You can reverse that by running the Office 2012 setup, doing a custom install and only installing eM Client.
2. You are confusing what the eM Client import filter does. The eM Client import filter imports the eM Client database of e-mails, contacts and calendars. It is not meant for importing .eml files as you seem to be trying.
keithvenn
Post by keithvenn » Fri Jun 30, 2017 10:41 am
Thank you Martin. My comment about EML files is therefore irrelevant.
If I re-phrase my comment and question - When I start Thunderbird and click on the Tools option to import from emClient, I get a message pop-up that says "TypeError: Stm.getColumnDecltype is not a function".
I checked all the data files are in the AppRoaming file, and everything seems to be OK.
I have now uninstalled the Office 2016 I bought yesterday, and re-installed 2012, together with emClient again.
However, I would like to try 2016 again, but need to know what is causing the "TypeError: Stm.getColumnDecltype is not a function" error message.
Post by martin-k » Fri Jun 30, 2017 10:51 am
1. You can install eM Client and SoftMaker Office 2016 in parallel by:
- running a custom install of SoftMaker Office 2012 and choosing only eM Client.
- installing SoftMaker Office 2016 and declining the offer to uninstall SoftMaker Office 2012.
2. As for your eM Client import problem, we would need your complete eM Client database to try to reproduce the problem here. For that, you need to zip the whole "eM Client for SoftMaker" folder and make it available to us using Dropbox or a similar service.
Scorpio47
Post by Scorpio47 » Mon Aug 07, 2017 4:45 pm
martin-k wrote:1. You can install eM Client and SoftMaker Office 2016 in parallel by:
Hallo Friends:
I too have this very same problem described above and I do not think that it has to do with my data but rather seems to be a glitch in the import module of the adapted Thunderbird version.
I shall gladly upload my data to dropbox (actually I already did), but I do not like the idea to share them with anyone in a public forum.....
Would it be possible to share it with martin-k in a PM? If so, how should I do that, please?
DANKE!
Scorpio47
P.S.
aus meiner email-Nachricht an den support:
"Ich meine irgendwo beim Browsen gelesen zu haben, daß das Problem inzwischen gelöst sei, kann aber diesen Hinweis nicht mehr finden.
Könnten Sie mir bitte verraten, wie ich meine Daten aus dem client von eM in die integrierte Version von Thunderbird importieren kann?
In der "normalen" Version von Thunderbird gibt es dieses feature nicht, da kann man nur einzelne Nachrichten importieren, nachdem man sie mühevoll erst aus eM exportiert haben muß. Das ist nicht zumutbar, finde ich...
Und bevor Sie mich nun auf IMAP hinweisen: nein ich nutze einen Mix aus IMAP und POP3 Konten und kann daher meine Nachrichten nicht (zumindest nicht vollständig) vom Server laden....
Danke für Ihre Hilfe und den entscheidenden und zielführenden Tip ;-)"
Leider kam der bisher noch nicht, weder per email, noch hier im Forum [-X
Post by sven-l » Mon Aug 07, 2017 5:20 pm
Vermutlich wird Ihren Post (außer wir hier im Support) niemand verstehen können, da Sie auf deutsch in einem englischen Forum gepostet haben. Das deutsche Supportforum finden Sie hier:
http://forum.softmaker.de/
Sie können mir gerne eine PM mit dem Downloadlink senden, dann hat niemand sonst Zugriff auf die Daten. Ich werde es dann weiterleiten. Vielen Dank!
Scorpio47
Post by Scorpio47 » Mon Aug 07, 2017 6:22 pm
Hi Sven,
sorry for that oversight... I have now translated my post into English (except the quote from my email) and I hope that people will understand it now.
As to the dropbox link, I´ll send that via PM then, OK.
THANK YOU and have a great day
Juergen
BJ1975
Post by BJ1975 » Sun Sep 03, 2017 11:12 pm
Has there been a solution to this issue? I am having the same problem.
Joy
Post by sven-l » Wed Sep 06, 2017 11:43 am
This will be solved in the future but unfortunately we have no solution right now. If you want a refund, please contact the sales department at sales(at)softmaker.de
Thank you!
Scorpio47
Post by Scorpio47 » Thu Sep 21, 2017 12:31 pm
That is a shame, Sven !!!
I, like most of your customers here, do not want my money back, we want a SOLUTION, and we want it NOW!
I do hope that this solution will be offered VERY SOON, because the problem should not have arisen in the first place, if your product had been thoroughly tested BEFORE releasing it.
It is sad that you seem to have adopted the notorious approach of Microsoft, where the motto always is: "it is good enough" instead of "it is GOOD". Customers should not be (mis)used as beta testers.
Have a good weekend, but - PLEASE - give us a solution FAST.
Kind regards
Return to “Thunderbird for Windows”
