email auto fill not working in Version 45.0
Questions and answers about Thunderbird for Windows
Princy557
Post by Princy557 » Fri Apr 29, 2016 10:33 am
After some time I have tracked down a problem with TB 45.0 where the auto fill in of email address's when writing emails has ceased to function.
This appears to be caused by the use of ' Faster autocompletion of e-mail addresses 1.0.25'. Once this was disabled the address's auto fill started to work again.
Are there any updates coming to fix this?
Regards
Kevin
Regards
Princy557
Re: email auto fill not working in Version 45.0
Post by sven-l » Fri Apr 29, 2016 10:39 am
Yes, our add-ons suddenly stopped working with Thunderbird 45. We will release updated add-ons in a few hours on our webserver. Then you can download and install them:
http://www.softmaker.com/en/download/add-ons
Princy557
Post by Princy557 » Fri Apr 29, 2016 11:37 am
Thanks Sven,
Can you put an update on this thread, I can tell a few others they are ready then.
Thanks for your updates when they arrive.
Regards
Princy557
Post by martin-k » Fri Apr 29, 2016 12:40 pm
We have made an interim release of the add-ons available. "interim" means that we know of a few cosmetic issues, but the add-ons otherwise work.
Go into Thunderbird, Tools > Add-ons, click on the Gear icon and check for updates.
Princy557
Post by Princy557 » Fri Apr 29, 2016 9:54 pm
Hi Martin-k, Sven
Thanks for the interim update.
Will there be a full update in the near future and will it have any new features?
Regards
Kevin
Regards
Princy557
Post by sven-l » Mon May 23, 2016 7:41 am
We updated all Add-ons and they will work properly now with Thunderbird 45.
Princy557
Post by Princy557 » Thu Apr 27, 2017 9:17 pm
Hi Sven
It's happening again....
Version 52.0.1 (32)
Not auto filling in the address book entries when sending an email.
Regards
Princy557
Post by martin-k » Thu Apr 27, 2017 9:24 pm
You should remove the autocomplete add-on. It doesn't work with TB 52 and isn't needed anymore.
Princy557
Post by Princy557 » Thu Apr 27, 2017 9:42 pm
Thanks Martin k
Appreciated 8)
Regards
Princy557
Return to “Thunderbird for Windows”
