Unable to see the cursor in my Presentations.
Post your questions, bug reports and suggestions here for Presentations 2016 for Windows.
Sammyone
Post by Sammyone » Tue May 29, 2018 4:39 pm
I am using a plain, 'Slate' colored back ground for Church Hymn Presentations.
I can Import (copy and paste text) no problem, but Editing is virtually impossible as the cursor only shows as a 'flicker' when moving it... due to a light gray rectangle that appears as soon as I click inside the Edit Box
I have tried to change the color of the cursor and changing the Slide color scheme to no avail...
Is there a setting or something else I am missing?
Thank you in advance.
Re: Unable to see the cursor in my Presentations.
Post by martin-k » Tue May 29, 2018 5:32 pm
Which version and revision of Presentations are you using? Help > About will tell you.
Sammyone
Post by Sammyone » Wed May 30, 2018 8:42 am
I am using...
Presentations 2017 (rev 768.1215)
Thankyou
Post by sven-l » Thu Jun 07, 2018 9:22 am
Please send a sample file to forum(at)softmaker.com referring to this thread.
Return to “Presentations 2016 for Windows”
