Presentations 2016 (Rev. 766) Doesn’t Load 16:9 Templates Properly
Post your questions, bug reports and suggestions here for Presentations 2016 for Windows.
RKanarek
Post by RKanarek » Fri Jun 23, 2017 3:30 am
Greetings,
When attempting to create a document using a template with a 16:9 aspect ratio, the template is loaded in 4:3 format. Interestingly, when “double-clicking” on a 16:9 template from Windows Explorer ‒ NOT from within Presentations ‒ Presentations opens the template properly.
Presentations does not seem to have a problem opening Presentations documents that are in 16:9 format.
Pres2016 - File (Template) Launched from File Explorer - Aspect Correct - Very Low Quality JPG.jpg
Pres2016 - File (Template) Loaded - Wrong Aspect Ratio - Low Quality JPG.jpg
Re: Presentations 2016 (Rev. 766) Doesn’t Load 16:9 Templates Properly
Post by sven-l » Wed Jul 05, 2017 10:04 am
This is reproducible here and I will report this issue to our developers. Thank you!
RKanarek
Post by RKanarek » Thu Jul 06, 2017 10:17 am
Thanks for the reply and for looking into the matter.
Post by sven-l » Thu Jul 20, 2017 2:58 pm
This problem has been solved and should no longer occur with the next service pack.
Return to “Presentations 2016 for Windows”
