Importing .rtf outline
Questions and answers about Presentations 2016 for Windows
BMoore
Post by BMoore » Thu May 12, 2016 4:22 pm
When I import a .rtf outline, it puts the title on one slide and all the points on a second slide.
I am just going to Insert/ Insert from outline. I am starting with a blank presentation.
I end up with two slides for each major point (should be one slide)
First slide is a title with no points. Second is points with no title.
Does it every time.
What am I missing?
Bryan
BMoore
Importing .rtf Outline 2
Post by BMoore » Thu May 12, 2016 4:31 pm
In continuing to try to insert an outline into Presentation 2016, I am concluding that it must be a bug.
When I have a blank line between major points, it imports the Title on one slide and the points on a second slide.
When I remove the blank line, it then shifts the points of each slide to the next slide.
First slide will be a title with no points.
Slide 2 will have title 2 with slide 1 points
Slide 3 will have title 3 with slide 2 points, etc
Alfred
Re: Importing .rtf Outline 2
Post by Alfred » Thu May 12, 2016 6:16 pm
Wouldn't this update have been better posted to your original thread, Bryan, thus keeping the discussion in one place? :?
Re: Importing .rtf outline
Post by sven-l » Fri May 13, 2016 10:52 am
I merged the topics.
Post by sven-l » Fri May 13, 2016 10:53 am
@BMoore: Could you please send us some sample file to forum(at)softmaker.de? Thank you!
BMoore
Post by BMoore » Mon May 16, 2016 2:22 pm
Attached is an example of a .rtf outline that I imported into Presentation.
The bullet points of the first slide are shifted to the second slide, the bullet points of the second slide are shifted to the third slide,
third to fourth and so on.
Importing an outline can be a nice feature if it works properly but counter productive if you have to cut and paste to fix it.
Thanks,
Bryan Moore
Is Healing For Today2.rtf
(14.73 KiB) Downloaded 177 times
Faith For Healing Class 2.prd
(72.5 KiB) Downloaded 325 times
Post by sven-l » Tue May 17, 2016 3:08 pm
Sorry to ask that but how exactly (step-by-step) did you import the rtf file into your presentation?
BMoore
Post by BMoore » Sun May 22, 2016 12:20 am
Are you serious?
Insert/Slide From Outline
Post by sven-l » Mon May 23, 2016 9:14 am
BMoore wrote:Attached is an example of a .rtf outline that I imported into Presentation.
Thanks,
Bryan Moore
I can see the issue now and will report that to our devleopers. Thank you!
BMoore
Post by BMoore » Wed Jun 08, 2016 4:37 am
I just tried to import another outline from rtf. The truth of the matter is that Presentation just doesn't import outlines well at all. It is one of those things that should either be fixed or take it off the menu. It wastes peoples time trying to make it work.
Thanks,
Bryan Moore
Return to “Presentations 2016 for Windows”
