Shadows and Underlining.
Questions and answers about Presentations 2016 for Windows
Phospic
Post by Phospic » Fri Oct 16, 2015 6:06 pm
I am having a problem with shadows and underlining in Presentation. It may be operator error.
I have prepared a slide show with a white background. My text is blue. I apply a shadow which is a light gray. I then save the slide show. When I open it the first few slides have the light gray background, but then after about four or five slides the shadow is black.
When I underline a word, the color is the same as the shadow. Sometimes. Other times it is the color of the text. When I turn the shadow off, it is always the color of the text. But I prefer to use shadows for clarity.
This occurs on both of my computers.
I would much appreciate any help.
Melvin
Re: Shadows and Underlining.
Post by sven-l » Tue Oct 20, 2015 5:09 pm
Could you please add a small sample file? I could not reproduce that problem here with a new file. Thank you!
Phospic
Post by Phospic » Tue Oct 20, 2015 10:49 pm
On the fourth slide it changes from a light grey shadow to a black shadow on both of my computers.
Slides.prd
(24.5 KiB) Downloaded 328 times
Post by sven-l » Tue Oct 27, 2015 3:49 pm
Ok, I can see the problem now and will inform the developers to have a look at this issue. Thank you!
Post by sven-l » Fri Oct 30, 2015 12:25 pm
This problem has been solved and should no longer occur with the next service pack.
Freddie
Post by Freddie » Fri Dec 18, 2015 11:01 am
This has been a long running issue with Presentations, especially with imported ppt files, but shadowing does indeed work much better with the latest patch.
Return to “Presentations 2016 for Windows”
