IF function help needed
Questions and answers about PlanMaker 2016 for Windows
snowshed
Post by snowshed » Fri Aug 02, 2019 5:19 am
It's been 50+ years since I needed to write any complex algebraic formulas, so the memory is not so great. LOL
I'm creating a spreadsheet listing all the various screen resolutions I can find. Once the resolutions are known, I want to calculate the aspect ratio of those resolutions.
For example, I put 1920 in a cell, and 1080 in another cell. Then in a 3rd cell, the aspect ratio of 16:9 is displayed.
The following formula, when placed in the 3rd cell, will give me a result of 16:9 when 1920 and 1080 are inserted in the first and second cells.
=$A27/GCD($A27,$B27)&":"&$B27/GCD($A27,$B27)
Every other resolution I've found and tried results in the correct aspect ratio.
Except... 1920 X 1200, and others. That gives you a result of 8:5, which, while technically correct, those are not the "numbers" you see listed in monitor specs. You see 16:10 in the specs.
When I enter these numbers, or similar, I'd like the result in the third cell to be 16:10, not 8:5.
It occurred to me the IF (if-th-else) function could be used to display 16:10 when the computations come out to 8:5. And if the math doesn't give you 8:5, it will display the correct aspect ratio.
Can it be done? How do I create the formula?
Thanks.
Re: IF function help needed
Post by miguel-c » Fri Aug 02, 2019 4:50 pm
You can nest IFs and the solution to your problem is:
=IF(($A27/GCD($A27,$B27)&":"&$B27/GCD($A27,$B27))="8:5","16:10",($A27/GCD($A27,$B27)&":"&$B27/GCD($A27,$B27)))
snowshed
Post by snowshed » Sat Aug 03, 2019 12:05 pm
Thanks, Miiguel, exactly what I was looking for.
And, I was so close in my experimenting. All I was missing are the quotation marks around 8:5 and 16:10.
