IRR formula error
Questions and answers about PlanMaker 2016 for Windows
hwl.gmx
IRR formula error
Post by hwl.gmx » Sat Nov 11, 2017 11:22 am
IRR formula function in Planmaker seems to be broken: each time I put series of cashflows which make the IRR exceeds 100%, the formula would return an error #NUM!
In other office suites, the IRR formula returned correctly, what is wrong here? I'm ready to pull the trigger to upgrade to Office 2018, but this one little error is really a deal breaker since I do plenty of IRR calculations.
Please advise.
Re: IRR formula error
Post by martin-k » Sat Nov 11, 2017 11:37 am
Give me a sample formula or file, and I'll investigate what's going on.
hwl.gmx
Post by hwl.gmx » Sat Nov 11, 2017 12:15 pm
Attached.
It's a simple calculation of IRR, however every time the IRR exceeds 100%, it will show the #NUM! error.
Sample IRR error.xlsx
IRR error - #NUM!
(6.45 KiB) Downloaded 280 times
Post by martin-k » Sat Nov 11, 2017 12:21 pm
Something is wrong with the file. Both in Excel and in PlanMaker, there are no formulas at all, just plain numeric values – and the error code #NUM in B5 (a literal error code, not a formula).
hwl.gmx
Post by hwl.gmx » Sat Nov 11, 2017 12:28 pm
Sorry for the mistake, here is the correct file.
Sample IRR error (b).xlsx
(6.48 KiB) Downloaded 265 times
Post by martin-k » Sat Nov 11, 2017 12:36 pm
I see that the value overflows in PlanMaker but not in Excel. I'll create a ticket for the developers to look at.
hwl.gmx
Post by hwl.gmx » Sat Nov 11, 2017 12:44 pm
Yes that is correct. FYI this error appears in your 2016 and 2018 programs (I'm using the paid 2016 version and 2018 trial version).
It would be great if this issue can be fixed, it's the only gripe I have before uninstalling the other office suites and started fully using your programs.
Thanks!
Post by martin-k » Mon Nov 13, 2017 5:03 pm
We are already working on fixing this.
Post by sven-l » Fri Nov 17, 2017 11:14 am
This issue has been solved now and should no longer occur in the next service pack.
hwl.gmx
Post by hwl.gmx » Mon Nov 20, 2017 9:48 am
Great!
Can you please kindly check the other thread I've made in the Planmaker 2018 section? Here is the link:
viewtopic.php?f=300&t=17249
It's about freeze pane bug, minor issue but annoying for those working with wide spreadsheets.
Thanks in advance!
