Line-break in cell
Questions and answers about PlanMaker 2016 for Windows
csilig
Line-break in cell
Post by csilig » Thu Oct 26, 2017 10:43 pm
Hi There!
I'm new on Planmaker on PC, therefore my observed small issue is might be not an issue, but missing feature. I used to work with Excel where I use ALT-Enter combination in cell to insert a line-break. I didn't find the similar solution. I tried the other mostly used combinations like CTRL-ENTER, SHIFT-ENTER etc. It was only working by selecting line-break insert from menu.
That's for now!
Regards
Csilig
harv91
Re: Line-break in cell
Post by harv91 » Sun Nov 05, 2017 5:25 pm
CTRL-Enter works for me
Thanks for any replies
Laurence
Post by martin-k » Mon Nov 13, 2017 5:03 pm
Yes, Ctrl+Enter is the correct key.
