Outliner
cpat
Outliner
Post by cpat » Thu Aug 31, 2017 12:27 am
I have a spreadsheet with a year's worth of data in rows which I am attempting to group into months.
IF I group January 1-31 all is fine.
Nexr I select FEb 1-28 and select Table:Outliner:Group, but the days for February are attached to the January group.
If I then select March 1:31 and select Table:Outliner:Group, MArch is added to the Jan-Feb group.
What do I need to do to put each month in its own group?
This seemed to be working earlier in another workbook but then it started acting weird.
cpat
Re: Outliner
Post by cpat » Fri Sep 01, 2017 5:04 pm
I have come up with a solution, or at least a workaround.
Re: Outliner
Post by sven-l » Mon Sep 04, 2017 11:45 am
Please send a sample file to forum(at)softmaker.de referring to this thread. We'll try to find a solution. Thank you!
