Page break not working
mrwinavl
Post by mrwinavl » Sun May 14, 2017 12:23 am
I'm using PlanMaker 2016 (rev 766.0331). I inserted a page break (Insert > Page Break > Insert Before Row...), but it is ignored when printing as well as in print preview. If I highlight that selected row and go to Insert > Page Break, it offers only to delete the page break, so it seems to think it's there. When it's supposedly inserted, there's no visual cue in the display, such as a heavy line or series of heavy dashes on the page break line. The Help file only refers to this one place to insert a page break. What am I missing?
Re: Page break not working
Post by sven-l » Mon May 15, 2017 11:09 am
Is your worksheet protected in some way? I tested it with PlanMaker 2016 for Windows rev.766.0331 and could properly add a page break the way you described it. The page break is visible as a thin horizontal line and when I check in the print preview (File=>Print Preview) it properly shows two pages.
I attached my sample file.
page_break.pmdx
(5.85 KiB) Downloaded 184 times
mrwinavl
Post by mrwinavl » Wed May 17, 2017 9:50 pm
So far all I had done was import one spreadsheet from Excel 2016, and it was on that one that I could not get the page break to work. I opened a new blank spreadsheet and tested the page break, and it worked correctly. So there's something about that imported spreadsheet that is causing the issue. There was a page break in the Excel sheet at the time it was imported, but there's nothing protected on either the original .xlsx file or the .pdmx version. Haven't had time to experiment more in the past few days though.
Post by sven-l » Thu May 18, 2017 9:31 am
If possible, please send us that file to forum(at)softmaker.de. We could check what's wrong with it. Thank you!
mrwinavl
Post by mrwinavl » Fri May 19, 2017 3:19 am
I am doing that. I would mention that in another attempt to figure this out, I started with a blank PlanMaker sheet, and then copied/pasted the cells from the original Excel sheet. It still does not page break in the print/preview where designated. In this sanitized (for dollar numbers) version, the page break is the line above row 89 (the solid gray bar above "SUMMARY").
Register - clean.pmdx
(49 KiB) Downloaded 133 times
Post by sven-l » Fri May 19, 2017 9:37 am
I can see the problem with your file and will inform the developer. I will report here as soon as we have a solution. Thank you!
mrwinavl
Post by mrwinavl » Sat May 20, 2017 12:37 am
Thank you
mrwinavl
Post by mrwinavl » Mon May 22, 2017 11:48 pm
Out of curiosity, I took a blank PlanMaker sheet, and then copied rows 1-87 inclusive from the Excel sheet and pasted them into the PlanMaker sheet. Then I copied rows 90 to the last row used from the Excel sheet, and pasted those in the same rows in the PlanMaker sheet. Then on the PlanMaker sheet, I inserted the page break above row 89, and the page break still did not work. So maybe it's not something that's coming over from Excel? Just thought I'd mention it while the developers are looking into this. Thanks.
Post by sven-l » Tue May 23, 2017 3:05 pm
The problem has been solved and should no longer occur with the next service pack.
kbharaninath
Post by kbharaninath » Wed Apr 04, 2018 2:06 pm
Hi,
I seem to be facing the same problem. When I open a fresh file on PlanMaker, the PageBreak works fine. But when I open an Excel File in PlanMaker, the PageBreak command does not seem to work. I have checked the software, and it says this is the latest version. Kindly check this and advise on the way forward.
Regards,
KB
Post by sven-l » Tue Apr 10, 2018 11:51 am
Could you please attach a sample file or send it to forum(at)softmaker.com referring to this thread?
