AutoFilter problem
Paolo
AutoFilter problem
Post by Paolo » Fri Dec 04, 2015 10:47 pm
If I want to filter some cells in a column using AutoFilter, I have to:
1) select the arrow on the first row, then appears the drop-down menu
2) deselect "All", and the drop-down menu disappear
3) select again the arrow on the first row, then appears the drop-down menu
4) select one filter, and the drop-down menu disappear
5) an so on
The AutoFilter drop down-menu should stay on-top, until I have finished to select what I want to filter, like on excel
Regards
Paolo
XL-Dennis
Re: AutoFilter problem
Post by XL-Dennis » Mon Dec 07, 2015 2:34 pm
Hi,
Let us know which latest update You're running.
Could You please upload a file as I'm not able to procude the output of the scenario You describe.
Kind regards,
Dennis
Paolo
Post by Paolo » Mon Dec 07, 2015 8:17 pm
Enclosed you find an example of what I Mean.
If I want to filter using the column "category", I have to select the arrow on "category", the drop down menu appears,
I deselect "All" and the drop down menu disappear, I have to re-select "category" and select what to filter, the drop-down
menu disappear again, so if I want to select more than one category I have to select continuosly the menu, and It's very uncomfortable.
Have a look at the AutoFilter inside Excel or LibreOffice, and you will understand what I want to achieve.
Regards
Paolo
Example.zip
(118.76 KiB) Downloaded 199 times
Paolo
Post by Paolo » Mon Dec 07, 2015 8:18 pm
I forgot, I'm using the latest update (749)
Regards
Paolo
Alfred
Post by Alfred » Tue Dec 08, 2015 12:27 am
Paolo wrote:I forgot
You can click on the pencil icon at the top right of your post to edit it.
XL-Dennis
Post by XL-Dennis » Tue Dec 08, 2015 1:31 pm
Paolo,
Thanks for the info :-)
In PlanMaker we need select the whole row with column names and then select Filter > AutoFilter.
When doing so we get the same output as when just having one cell selected in LibreOffice/Excel.
Sven et al: This should be a no-brainer to add to PlanMaker in a coming patch.
Kind regards,
Dennis
Paolo
Post by Paolo » Tue Dec 08, 2015 3:09 pm
In my experience, in Planmaker you can select only one cell or column, and apply the AutoFilter, It's the same as in Excel or LibreOffice.
It isn't necessary to select the whole row.
I don't know If I've explained well the issue.
The real problem for me is the drop down-menu of the AutoFilter containing the strings I want to filter (category in my example),
which disappear every time I select one voice inside the menu.
I repeat, to work correctly the menu should stay on-top until I click an "OK" button to apply the filter.
Attached two pictures to better show what I mean.
Regards
Paolo
XL-Dennis
Post by XL-Dennis » Tue Dec 08, 2015 4:10 pm
Sorry for not understanding the issue better...
This is something that SoftMaker should resolve in a coming update of PlanMaker.
Sven, this shouldn't be an issue to add, right?
Kind regards,
Dennis
Post by sven-l » Wed Dec 09, 2015 12:41 pm
I will refer that problem to our developers and inform you as soon as I have an answer.
Paolo
Post by Paolo » Wed Mar 16, 2016 10:08 pm
I've intalled service pack Revision 752, but the problem is still there, although in the list of changes
there is "The Autofilter menu is now more user-friendly"
Sorry to say that Autofilter has the same problem, It doesn't stay on-top until I've finished to select what to filter.
Hope in a next service pack.
Also italian translation is still incomplete.
Regards
Paolo
Jim-J
Post by Jim-J » Thu Mar 17, 2016 12:31 pm
I informed the developers about your request. As soon as I receive a response, I'll will inform you here.
Jim J.
MissMarvy
Post by MissMarvy » Thu Feb 09, 2017 6:41 pm
I like this idea, plus I would like to be able to filter in one step as in 2012. Now I have to deselect all and then select my filter. Perhaps a right-click could reverse the selections?
Paolo
Post by Paolo » Sat Mar 18, 2017 4:03 pm
Service pack Revision 765, problem still not solved. More than one year since the first report and no solution.
I've almost lost my hope. I use the Autofilter function a lot, and inside Planmaker still does not work as it should.
Also Italian translation still incomplete. (I propose myself to finish the work, if necessary)
I'm quite disappointed, thinking to switch to other software.
Regards
Paolo
