Is it possible to create custom date format?
Questions and answers about PlanMaker 2016 for Windows
Levente
Post by Levente » Thu Nov 05, 2015 10:21 pm
In Hungary we refer to dates in "YYYY. mm. dd." format, but Planmaker has only "dd. mm. YYYY." style. The closest format is "YYYY-mm-dd" but I'd prefer "YYYY. mm. dd." style date when formatting a cell. Is it possible to add somehow such a custom cell format?
Re: Is it possible to create custom date format?
Post by Jossi » Fri Nov 06, 2015 3:47 pm
In Format > Cell..., the last category is "Custom". There you can define your own date format, in this case "YYYY.MM.DD".
Levente
Post by Levente » Fri Nov 06, 2015 5:04 pm
Yes, I know that but my problem is this: I have a spreadsheet that has cells formatted as "YYYY. mm. dd" date format. If I import this file into PlanMaker date fields are displayed in dd.mm.YYYY style. Not exactly what I wanted.
I tried to reformat date fields as YYYY-mm-dd and then import the spreadsheet into PlanMaker. This time PlanMaker displayed cell correctly in YYYY-mm-dd format.
I'd like to avoid reformatting date fields or incorrect order of date representation that's why I'd need YYYY. mm. dd as a date format not a custom format.
XL-Dennis
Post by XL-Dennis » Sat Nov 07, 2015 3:42 pm
I don't follow You here. Custom format does not differ from built-in-format or do You get any wrong output when using the custom format?
Kind regards,
Dennis
Levente
Post by Levente » Sun Nov 08, 2015 11:32 am
I try to explan it in another way. I've got an existing xls sheet where cells are formatted as date in "YYYY.mm.dd" format. I open the excel sheet using PlanMaker and the same cells are represented as date in "dd.mm.YYYY" format. (Note the order of the day, month, year is reversed!) I feel this is some kind of an incorrect way of using existing excel sheets.
If I want to have the cells displayed in PlanMaker in the correct order, that is as YYYY.mm.dd, I need to reformat the cells as custom type after opening it. I'd like to avoid it.
Levente
Post by Levente » Sun Nov 08, 2015 1:31 pm
The same problem: viewtopic.php?f=233&t=15049
bsbd
Post by bsbd » Sun Nov 08, 2015 5:12 pm
You're right, Levente. I've added a comment over there on the PlanMaker HD for Android tablets forum.
-bsbd
XL-Dennis
Post by XL-Dennis » Mon Nov 09, 2015 12:43 pm
Thanks for clarifying it. What I suggest is to use a macro script to manage the date issue.
The following script resolve the issue:
Code: Select all
option explicit
dim pm as object
dim wbBook as workbook
dim wsSheet as worksheet
dim rnData as range
set pm = createobject("planmaker.application")
'Make Planmaker available
pm.application.visible = true
pm.application.activate
'Open the workbook
set wbbook = pm.workbooks.open ("c:\Data\DateData.xlsx", False , pmFormatMSXML)
set wssheet = wbbook.sheets("Data")
set rnData = wssheet.range("A1:A2000")
'Format the range with our custom date format
rndata.numberformatting.dateformat = "YYYY.mm.dd"
'Save the changes
wbbook.save
'Cleaning up
set rndata = nothing
set wssheet = nothing
set wbbook = nothing
set pm = nothing
If You put it in production then I would recommend that You also add an error management to the script.
Kind regards,
Dennis
Levente
Post by Levente » Mon Nov 09, 2015 10:26 pm
XL-Dennis wrote:Thanks for clarifying it. What I suggest is to use a macro script to manage the date issue.
Thanks for the script. I know this date handling issue is not a big deal and could be solved with some workaround, but I thought it wouldn't be a big deal to modify the code of PlanMaker to make the workaround unneccessary.
MichiganMarty
Post by MichiganMarty » Fri Sep 29, 2017 1:45 am
The script is not an option for my problem.
We share a drive and the excel spreadsheet is and always has been correct. Now, I am using freeoffice and whenever I open this HUGE file with over1500 entries on 52 work sheets, it screws up the entire workbook. We cant be using a script everytime we want to edit it and save it.
Is this going to be fixed?
By the way, I changed the regional settings and PlanMaker STILL DOES IT!
Post by martin-k » Fri Sep 29, 2017 10:04 am
MichiganMarty wrote:The script is not an option for my problem.
Please provide a sample document that exhibits the observed behavior. I can then push this issue with the developers.
Winfried
Post by Winfried » Tue Jan 16, 2018 2:51 pm
Hello,
I'll piggy-back on this thread, since I have almost the same need.
I'm giving SoftOffice PlanMaker a try, and need to format cells so that dates include the day's name, short or long, eg. "Mon" or "Monday".
The Custom section of the "Cell" dialog doesn't include help so I don't know if SO includes this option.
Thank you.
Post by martin-k » Tue Jan 16, 2018 3:58 pm
DDD gives you the short day name, DDDD the long one.
As you have a French e-mail address: With the French user interface, it is JJJ and JJJJ, respectively.
Winfried
Post by Winfried » Tue Jan 16, 2018 4:05 pm
Thanks !
