Font size of row numbers, column letters and worksheet tabs
Questions and answers about PlanMaker 2016 for Windows
Steve1319
Post by Steve1319 » Wed Jun 17, 2015 2:24 pm
Hi
Does anyone know if it's possible to increase the font size of the row numbers, column letters and worksheet tabs - they're usable at the size they are but a little smaller than I'd prefer. I've tried all the options and settings but haven't found any way of changing them.
Many thanks for any help!
Robin Holt
Re: Font size of row numbers, column letters and worksheet tabs
Post by Robin Holt » Wed Jun 17, 2015 6:58 pm
I'm not sure if it would help or not but you might want to increase the zoom level slightly to say, 110% or so. That might increase the visibility of the row numbers and column tabs but may not help with the worksheet tabs. If that works for you, consider saving the zoom level in the "normal.pmvx" template and it will automatically be available when you want a new workbook
Steve1319
Post by Steve1319 » Thu Jun 18, 2015 9:42 pm
Thanks - works well for the rows and columns.
The worksheet tabs remain small, but I can always use BLOCK CAPS to make them appear bigger.
Thanks again!
ckit
Post by ckit » Tue Aug 18, 2015 6:53 am
I find the font size for Sheet Tabs to be too small as well, LibreOffice Calc is only slightly better though.
Seems to be a stupid limitation of most spreadsheet apps?
Post by sven-l » Wed Aug 19, 2015 11:17 am
It is not yet possible to edit the font size for Sheet Tabs. This is on the agenda for the future.
Douglas Clarke
Post by Douglas Clarke » Fri Oct 23, 2015 12:31 pm
I have recently installed planmaker 2016 and I find that a file created in the previous version does'nt show the worksheet tabs at all,
Why is that??
Post by sven-l » Thu Oct 29, 2015 4:06 pm
Douglas Clarke wrote:I have recently installed planmaker 2016 and I find that a file created in the previous version does'nt show the worksheet tabs at all,
Why is that??
Could you please attach a sample file or send one to forum(at)softmaker.de referring to that thread? Thank you!
