Print Merge and PDF files
Post your questions, bug reports and suggestions here for TextMaker 2016 for Windows.
snowshed
Post by snowshed » Sat Feb 02, 2019 11:45 pm
I've created a form letter with database fields to generate letters to addresses in a database. The database is set with the document.
Is there a way to use Print Merge, or something else, with a PDF printer driver instead of a printer, and have multiple pdf files instead of physical prints?
That would give me a PDF file/letter that I can email instead of a physical letter to take to the post office.
Re: Print Merge and PDF files
Post by sven-l » Fri Feb 08, 2019 9:50 am
You can use a PDF printer instead of your physical printer in the print dialog.
snowshed
Post by snowshed » Fri Feb 08, 2019 12:39 pm
Hi, Sven,
That is what I tried. That results in a single PDF file containing multiple letters. I would like multiple PDF files that are individual letters.
Post by sven-l » Fri Feb 08, 2019 1:57 pm
Use the print preview. Here you can preview every single letter (dataset) of your mail merge and print it or export it into a PDF file.
snowshed
Post by snowshed » Fri Feb 08, 2019 3:06 pm
True. But... What if I'm a small business, and want to send out 250 files? There's not much time savings in having to create 250 individual files. :-)
Post by martin-k » Fri Feb 08, 2019 3:08 pm
I know it doesn't help you much at the moment, but the next version of FlexiPDF will let you split a large PDF file into batches of individual PDFs, such as every two or three pages.
snowshed
Post by snowshed » Fri Feb 08, 2019 3:42 pm
Will it be possible to link FlexiPDF to TextMaker to automate splitting of the PDF into the individual documents?
Post by martin-k » Fri Feb 08, 2019 3:48 pm
This is currently not planned.
snowshed
Post by snowshed » Fri Feb 08, 2019 4:16 pm
Thanks, Sven.
