Any way to "Make it fit"?
ecbritz
Post by ecbritz » Sun Oct 01, 2017 10:12 am
WordPerfect X9 to which I am attached like one would be to a veteran car, i.e. without finding it really serviceable any longer, has some features I do love. One such function is "Make if fit". When you do Format > Make it Fit in WordPerfect, you select the number of pages the document must fit into, filling all pages with text. Suppose you have typed six-and-half pages and want this to fit into four pages. You simply do Format > Make it Fit, then select 4 pages. The font size will be adjusted, from say 12pts to 9.7pts, automatically. If you select 9 pages, the font will be enlarged to say 16.9pts to adapt the same text to 9 filled pages. Is there any way to do this with Textmaker? It's marvelous for for instance designing a form that needs to fit snugly onto one page. I simply experiment with font sizes to get the same result. But I would love to discover an instant and automatic way.
Softmaker 2016 & 2018.
Alfred
Re: Any way to "Make it fit"?
Post by Alfred » Sun Oct 01, 2017 12:41 pm
Auto-fitting to a (fixed height) text frame would suffice for a block of text that "needs to fit snugly onto one page", but I can't see how to achieve this in TextMaker.
ecbritz
Post by ecbritz » Sun Oct 01, 2017 3:23 pm
I attach an example of "Make it Fit" in the form of two pdf's. WordPerfect has many such functions not found in other word processors and a wonderful user's forum. But for doing some real work rather than fiddling around I find Textmaker the ideal word processor. Still, Make it Fit can be very handy. Hint, Softmaker, hint.
Made to Fit on one page.pdf
(24.45 KiB) Downloaded 151 times
Original 2 pages.pdf
(24.95 KiB) Downloaded 141 times
Post by sven-l » Fri Nov 10, 2017 2:25 pm
ecbritz wrote:WordPerfect X9 to which I am attached like one would be to a veteran car, i.e. without finding it really serviceable any longer, has some features I do love. One such function is "Make if fit". When you do Format > Make it Fit in WordPerfect, you select the number of pages the document must fit into, filling all pages with text. Suppose you have typed six-and-half pages and want this to fit into four pages. You simply do Format > Make it Fit, then select 4 pages. The font size will be adjusted, from say 12pts to 9.7pts, automatically. If you select 9 pages, the font will be enlarged to say 16.9pts to adapt the same text to 9 filled pages. Is there any way to do this with Textmaker?
There is no way to do this with TextMaker. I will refer your suggestion to the product management.
