Using Tables and Zoom Hides Document Off Screen
Post your questions, bug reports and suggestions here for TextMaker 2016 for Windows.
AJ_
Post by AJ_ » Mon Jun 26, 2017 6:14 am
When I use the zoom/magnify function with a document containing tables, and the document goes off screen, the horizontal scroll bar is inoperative. The horizontal scroll bar does not permit scrolling to the right to view the hidden portion of the document.
Re: Using Tables and Zoom Hides Document Off Screen
Post by martin-k » Mon Jun 26, 2017 8:31 am
You are posting in the Windows forum. Does your post refer to TextMaker for Windows or TextMaker HD for Android?
AJ_
Post by AJ_ » Mon Jun 26, 2017 8:54 am
For Windows.
Post by martin-k » Mon Jun 26, 2017 9:13 am
Go to Tools > Options > View and activate the horizontal scrollbar (it is actually on by default, so it seems you turned it off once).
AJ_
Post by AJ_ » Mon Jun 26, 2017 9:25 am
It is already activated and works fine when tables are not used in a document. If tables are used then the scroll bar does not work.
Post by martin-k » Mon Jun 26, 2017 9:30 am
I cannot reproduce this. Please upload a sample document and a screenshot.
AJ_
Post by AJ_ » Mon Jun 26, 2017 10:09 pm
I have deleted the file that was causing the problem. It may have been a version bug or something. You can delete this topic if you wish. Thanks.
