[Suggestion] Allow commenting an arbitrary range of text inside a table cell, not just the entire cell
Post your questions, bug reports and suggestions here for TextMaker 2016 for Windows.
Temcat
Post by Temcat » Fri Mar 24, 2017 2:22 pm
Currently, I cannot add a comment to a specific word or phrase inside a table cell: it is always the entire cell that gets marked as the commented range. This impedes collaboration on documents with tables, as either I have to spend additional time explaining what exactly the comment refers to or someone else has to put extra effort in figuring that out. Consider adding the ability to add a comment to an arbitrary range of text inside a table cell.
Re: [Suggestion] Allow commenting an arbitrary range of text inside a table cell, not just the entire cell
Post by sven-l » Mon Mar 27, 2017 10:39 am
I will refer your suggestion to the product management. Thank you!
