[Suggestion] Check spelling of the selected text
Post your questions, bug reports and suggestions here for TextMaker 2016 for Windows.
Temcat
Post by Temcat » Wed Mar 22, 2017 5:51 pm
Can you add the ability to check spelling of the selected text, ignoring all the rest?
Re: [Suggestion] Check spelling of the selected text
Post by sven-l » Fri Mar 24, 2017 9:19 am
I will refer that suggestion to the product management.
Temcat
Post by Temcat » Fri Mar 24, 2017 2:14 pm
sven-l wrote:I will refer that suggestion to the product management.
Consider, for example, a huge multi-lingual table where content in a specific language resides in one or two adjacent columns. Text languages in the document may not always be properly marked to be able to restrict spelling check by language.
