some questions about hotkeys (shortcuts)
leopoldus
Post by leopoldus » Thu Sep 01, 2016 12:00 pm
In the TextMaker manual one can find two sections with predefined hotkeys lists, "Keyboard shortcuts for menu commands" and "Keyboard shortcuts for editing text", the both are quite short. Is this really the full list of currently available shortcuts?? :o Or may be there are other hotkeys too, which for some reason are not included in this two lists?
And another question. It seems to be reasonable if the existing hotkey would be displayed as a tooltip when hovering a mouse cursor over the main menu entry which has the associated hotkey. Is there any option to get it?
Thanks!
Re: some questions about hotkeys (shortcuts)
Post by sven-l » Fri Sep 02, 2016 8:34 am
Invoke Tools=>Customise=>Keyboard Mappings. Select "Default" and click on "Edit". Now select a group and a command and check if there is a hotkey assigned or not. If not, feel free to define one.
After you set a hotkey to a specific function it is shown in the tooltip, too.
