autotext/smarttext
dhlytle
autotext/smarttext
Post by dhlytle » Wed Aug 31, 2016 12:10 am
Part of my use of Textmaker has aspects of a diary and task management.
I have a SmartText entry that expands to "Called and left voice message ...".
I leave space to type in the date and time.
I would love to find a way to have the date and time automatically precede the message.
I'm guessing there is no way to call a macro from within Smarttext.
On the other hand, it I worked on it, I might find a way to call a script that would put the time and date and then call the Smarttext.
Maybe I would just make the text be part of the script.
Any other ideas?
Thanks.
Re: autotext/smarttext
Post by sven-l » Wed Aug 31, 2016 10:38 am
I see no solution for this as a macro is not available. I will refer your wish as a suggestion to the product management.
Post by Jossi » Wed Aug 31, 2016 1:09 pm
As a workaround you might assign keyboard shortcuts to the current date and time.
Invoke Tools > Customise > Keyboard Mappings... , click "Edit", then select "Insert" in the left column and "Insert date" in the right column, type a shortcut into the "Please press accelerator" field, e. g. Alt+D, and click "Add". Repeat this for "Insert time", e. g. with Alt+T. After leaving the dialogue box with "OK" and "Apply" you get the desired result by typing ALt+D, Alt+T and your SmartText abbreviation.
Admittedly, these are three hotkeys instead of one, but still easier than typing in the date and time manually.
