any option to reorder the tabs on the tabs pane
leopoldus
Post by leopoldus » Tue Aug 02, 2016 9:13 am
Hi,
Is there any way to reorder tabs on the tabs pane? The most applications with tabbed (MDI) interface under Windows can make it, but I was not able to find any solution in TextMaker.
Another question regarding tabs. Is there any hotkey to navigate through tabs? I have tried Ctrl+Tab, as in the most of the modern browsers, and some other hotkeys too, but it does not work.
Thanks!
Re: any option to reorder the tabs on the tabs pane
Post by martin-k » Tue Aug 02, 2016 10:00 am
Tab reordering comes with the next major version.
Cycling through tabs is done with Ctrl+F6 and Ctrl+Shift+F6.
