I want to open documents in new windows (no tabs!)
Aryllia
Post by Aryllia » Fri Jun 24, 2016 11:33 pm
I'm sure there are a lot of times when opening documents in tabs within one window is just smashing and great. But I kind of hate it and it is just very frustrating to work with because of a) my itty bitty tiny screen and b) well over a decade's worth of writing habits. Having two (or more) documents open in separate windows just makes things infinitely easier for me. Is there a way to do this in TextMaker? Has it been possible in a previous version that I can revert to? Or, if I have to uninstall it and find a replacement, are there any plans to at least make it possible in the future so I can come back then? Sorry, I just can't work with tabs in my writing software.
Robin Holt
Re: I want to open documents in new windows (no tabs!)
Post by Robin Holt » Mon Jun 27, 2016 10:16 am
Go to Tools=>Options=>General and you will find a selection under "Document Tabs". You can turn off tabs there and it may be what you're looking for.
