moving two or more open documents from one screen to another.
Post your questions, bug reports and suggestions here for TextMaker 2016 for Windows.
delphi15
Post by delphi15 » Sat Apr 30, 2016 8:06 pm
In my consulting work I use TextMaker 80% of the time. However, have a strange problem. My workstation computer has four monitors. If I Restore down an open document, it reduces in size, along with other open documents, however, when I try to move it to another monitor (screen), it just runs off the side of the original screen but not to another monitor. This is a new problem to me with the 2016 version.
What is the workaround?
Thanks,
Harvey Knauss
Re: moving two or more open documents from one screen to another.
Post by sven-l » Mon May 02, 2016 9:59 am
It did not happen with TextMaker 2012? We have users with three monitors who can work properly and moving the text window around is no problem. Does that same problem also happen when you try this with another program like Libre Office Writer or MS Office?
Did you mean the program window or the document window? Please note that is is not possible to move the document window to another monitor that the program window is in.
