Problem Saving Docs...
Mikayl
Post by Mikayl » Thu Mar 03, 2016 3:16 pm
When I try to save a document and click "Save As", I get a box containing the path. However, as I negotiate the path I reach a point where all the folders are there except the one I want to enter. When I look for it in Windows its there, but not when I try to negotiate to it through Textmaker. Currently I'm having to save the file to my desktop and then open the destination in Windows and drag and drop the file to get it where it needs to be. Any suggestions would be truly appreciated.
Alfred
Re: Problem Saving Docs...
Post by Alfred » Sat Mar 05, 2016 1:09 pm
That's an odd one, Mikayl! Are there any spaces or non-Latin characters in the file name or the folder path?
Post by Jossi » Sat Mar 05, 2016 4:25 pm
Which version of Windows are you using? I have a vague recollection that there was a length limit for path names in Windows. Are you trying to save the document to a location deep in subfolders with long names?
Mikayl
Post by Mikayl » Sun Mar 06, 2016 1:25 pm
I'm using Windows 8. Yes....the path leading to the folder is really long....If there is a limit to the length, I think I could well have exceeded it. :-o
Mikayl
Post by Mikayl » Sun Mar 06, 2016 1:29 pm
Alfred wrote:That's an odd one, Mikayl! Are there any spaces or non-Latin characters in the file name or the folder path?
No.....the characters are normal. No spaces either....
Alfred
Post by Alfred » Sun Mar 06, 2016 3:51 pm
Mikayl wrote:I'm using Windows 8. Yes....the path leading to the folder is really long....If there is a limit to the length, I think I could well have exceeded it. :-o
Try mapping a network drive to the folder.
Jim-J
Post by Jim-J » Mon Mar 07, 2016 2:00 pm
Do you still have the saving problem? If so, can you please send a screenshot of the error message?
Can you also send the sminfo.txt (Invoke "Help->About->Write System Information")?
Jim J.
Post by Jossi » Mon Mar 07, 2016 9:57 pm
If I understand this document correctly, the maximum length for a path is 260 characters:
https://msdn.microsoft.com/en-us/librar ... px#maxpath
