rev. 768: “Check for Update” fails
Post here those questions, bug reports and suggestions for SoftMaker Office 2016 for Windows that do not fit in any of the application-specific subforums.
Dirge
Post by Dirge » Fri Jan 12, 2018 12:38 am
Since updating from rev. 766 to rev. 768 using the newest service pack, the Help > Check for Updates feature no longer works. When I try to check for updates, I receive the following error message:
It is not possible to establish a connection to www.softmaker.com.
The following error has returned:
12157
This problem occurs on my Windows XP (SP3) PC, which has an Athlon XP CPU without SSE2 support, but it does not occur on my dad’s Windows 7 PC.
Re: rev. 768: “Check for Update” fails
Post by sven-l » Mon Jan 15, 2018 1:40 pm
Please try again. It should work now. I tried it a few seconds ago with rev.768 and the update check worked properly (but of course it hasn't found any new update).
Post by sven-l » Mon Jan 15, 2018 1:49 pm
Edit: Ok, the update checker does not work with Windows XP but with Windows 10. I reported this to the developers. Thank you!
Dirge
Post by Dirge » Mon Jan 15, 2018 5:03 pm
Thanks for the fast response.
Post by martin-k » Thu Jan 18, 2018 4:29 pm
Windows XP does not let us access the update checker using https. Any newer version of Windows does.
This won't be changed in the near future. Simply disable the update checker. If we release another service pack for SoftMaker Office 2016, we will notify you via our newsletter.
Dirge
Post by Dirge » Thu Jan 18, 2018 6:26 pm
Sounds reasonable to me. Thanks.
