Remove hidden Smash icons from SysTray ?
Post here those questions, bug reports and suggestions for SoftMaker Office 2016 for Windows that do not fit in any of the application-specific subforums.
bawldiggle
Post by bawldiggle » Sat Dec 16, 2017 9:38 am
Smash.exe
Trialing "Softmaker FreeOffice 2016 (rev 767.0516)
- I clicked ... Utilities -> Smash ... and waited for something to show.
- found this Softmaker v2006 thread smash.exe
- checked my Sys.Tray and found two Softmaker icons for Writer and Planner, hidden in sys.tray
- the 2009 solution by sven-1 has not helped
- ... Smash.exe is not listed on my msconfig.exe list
- nor is it listed on "SysInternals - AutoRuns" as User (or Administrator)
How do I remove the SysTray items ?
- I don't think it is wise to delete "Smash.exe" until I get more experienced with SoftMaker Office
- I know how to remove the Smash shortcut on Programs -> SoftMaker FreeOffice 2016 -> Utilities -> Smash
Smash is configured to not run at OS startup
I only discovered "SoftMaker 24 hours ago and downloaded today
I would appreciate any help, thank you :)
SPECS:
OS: Win-7 PRO 64-bit
SFO: Softmaker FreeOffice 2016 (rev 767.0516)
Re: Remove hidden Smash icons from SysTray ?
Post by martin-k » Mon Dec 18, 2017 10:28 am
You ran a "full" install instead of a standard install. This gives you all components, even Smash which is not needed in Windows 7 anymore.
Uninstall the program, install it again as a standard install.
