SMO2016 refusing to start
General questions and answers about SoftMaker Office 2016 for Windows. Don't post application-specific questions here, but in the appropriate subforum.
JohnWasilewski
Post by JohnWasilewski » Tue Dec 13, 2016 9:27 am
I have a Lenovo P50s laptop (core i7 vPro) with Windows 8.164 bit with 16GB memory and a SSD, connected to LAN and/or WiFI.
SM-Office worked when I first installed it, on or about 3rd/4th December 2016, but now it doesn't work any more.
Save for the problem I describe below, everything on the laptop works normally.
When I double-click the TM icon:
- sometimes, nothing at all seems to happen, but
Task Manager shows it as a background process
using 32% of CPU and 8MB of memory
- sometimes I get a grey window with the 'TextMaker'
title bar plus window-close and shrink gadgets, and
with a white menu bar with a single entry - 'Help' -
which I cannot click because the 'busy' wheel remains
permanently on. The Task Manager, then shows TM
as an 'App', which is 'not responding'.
PlanMaker and Presentations also won't start.
BasicMaker DOES start.
I have also tried UNinstalling and re-installing SMO2016.
It did not help.
I'm therefore stuck,
John
00971-50-642-2378
Re: SMO2016 refusing to start
Post by martin-k » Tue Dec 13, 2016 9:28 am
Run TextMaker.exe with the -debug parameter:
TextMaker.exe -debug
This will create a log file "tmlog.txt" in My Documents. Please upload it here.
JohnWasilewski
Post by JohnWasilewski » Tue Dec 13, 2016 5:05 pm
Thanks Martin. I'll do that tomorrow when I'm back in the office.
I'm sure it'll be something trivial causing it.
John
JohnWasilewski
Post by JohnWasilewski » Wed Dec 14, 2016 9:40 am
Various files attached, which might help.
As you see, TM2012 runs OK. It's TM2016 and other SMO2016 executables that won't run.
John
Post by martin-k » Wed Dec 14, 2016 9:52 am
John, no file was attached. We just need the log file for TextMaker 2016.
JohnWasilewski
Post by JohnWasilewski » Wed Dec 14, 2016 10:08 am
I keep trying to attach files. Not sure what I'm doing wrong.
I'll send them by email.
John
JohnWasilewski
Post by JohnWasilewski » Wed Dec 14, 2016 10:26 am
Trying again to send files...
tmlog for TM2016.txt
(65.12 KiB) Downloaded 236 times
tmlog for TM2012.txt
(71.03 KiB) Downloaded 197 times
JohnWasilewski
Post by JohnWasilewski » Wed Dec 14, 2016 10:27 am
I'd tried to attach too many.
tmw16config.ini
(3.17 KiB) Downloaded 198 times
tmw12config.ini
(523 Bytes) Downloaded 210 times
JohnWasilewski
Post by JohnWasilewski » Wed Dec 14, 2016 10:28 am
I think you have the files now, that I was trying to send.
John
Post by sven-l » Thu Dec 15, 2016 11:20 am
I will refer that issue to our developers and report here as soon as I have a solution.
Post by sven-l » Fri Dec 16, 2016 11:31 am
Please try the following:
- Try to use a different default printer when starting.
- Temporarily rename the settings folder (in the SoftMaker folder) to see if some setting causes this.
Does it help?
JohnWasilewski
Post by JohnWasilewski » Fri Dec 16, 2016 5:08 pm
I have tried changing the default printer and disabling the Settings folder.
I has not helped.
Here's another TMlog.txt file (attached).
John
tmlog.txt
(64.04 KiB) Downloaded 215 times
JohnWasilewski
Post by JohnWasilewski » Fri Dec 16, 2016 6:57 pm
I've tried using 'Process Explorer' to see if I can watch what TM2016 opens and see how far it gets.
When running TM2012, 'Process Explorer' reports that TM has run the MS printer driver host, splwow64.exe.
When I try running TM2016, however, 'Process Explorer' DOES NOT report that TM has run splwow64.exe.
This might be a helpful clue to how far TM2016 manages to reach in its startup process.
I am also finding, sometimes, TM2016 displays the attached incomplete screen, with the 'busy' icon spinning endlessly.
John
Post by sven-l » Mon Dec 19, 2016 7:52 am
Thank you! I informed the developers.
Post by sven-l » Tue Dec 20, 2016 8:12 am
What would help us is using ProcMon (https://technet.microsoft.com/en-us/sys ... nitor.aspx), with a filter "Process Name" is "TextMaker.exe". Then start TextMaker. This will create a rather big log. Could you please send it to us? Thank you!
