Service Pack 742
General questions and answers about SoftMaker Office 2016 for Windows. Don't post application-specific questions here, but in the appropriate subforum.
dvally
Service Pack 742
Post by dvally » Fri Sep 04, 2015 3:27 pm
I tried updating my version of SMO2016 with the latest SP, but got the following warning from Webroot SecureAnywhere.
The file was removed after downloading. Can you shed any light on this for me please?
LanceGary
Re: Service Pack 742
Post by LanceGary » Fri Sep 04, 2015 7:42 pm
I use Kaspersky's antivirus software. It allowed the update to install without problems.
Lance
griffinnova
Post by griffinnova » Fri Sep 04, 2015 9:03 pm
I also have Webroot and received the same response regarding a W32.malware.gen file being in the Service Pack. Webroot removed the file and, after reading descriptions of that malware file (i.e., it can back door credit card information and other personal information from your computer), I will not load the Service Pack until there is a full explanation in this forum. Thank you.
EricC
Post by EricC » Sat Sep 05, 2015 1:01 am
Webroot is not liking something with the 7-zip self extracting archive. After I restored the file and extracted its contents, I had Webroot scan the extracted folder and there were no issues. So it's a false positive.
cyberdiva
Post by cyberdiva » Tue Sep 15, 2015 2:17 am
I came to the forum to report a very similar occurrence. Today I installed the update ofw16_742.exe, and as it was installing, a little box popped up from Microsoft Security Essentials telling me it was cleaning the malware. The box then disappeared. After the update was installed, I went into MSE and looked at the history. It informed me that it had detected PSW:Win32/Sinowal.gen!Q. The alert level was said to be Severe, and the Action Taken was "Quarantined." However, it went on as follows:
The following error occurred: Error code 0x80508023. The program could not find the malware and other potentially unwanted software on this computer.
Category: Password Stealer
Description: This program is dangerous and captures user passwords.
Recommended action: Remove this software immediately.
Items:
file:C:\Program Files (x86)\SoftMaker Office 2016\TextMaker.exe
There was also a link to more information from Microsoft. It described the malware this way: "This threat is classified as a Trojan - Password Stealer. Typically, a password stealing trojan installs a keystroke logger (commonly referred to as a keylogger) which records keystrokes and sends the recorded information to remote attackers. Some keyloggers monitor only keystrokes involved in specific types of web-based transactions. For example, a keylogger may include a component that monitors browser activity, only recording keystrokes when certain bank or ecommerce sites are accessed. Other types of password-stealing trojans include those that capture screenshots in an attempt to bypass graphic-based security measures. This threat is detected by the Microsoft antivirus engine. Technical details are not currently available."
I'm not sure what to make of this. MSE did but did not quarantine this program which it found but could not find. ??? Although I didn't install the update until today, I had downloaded it on September 4, the same date as earlier reports in this thread. Is it possible that the update file available on that date was compromised in some way? I'd be most grateful for some advice about how to proceed.
SoftMaker Office 2016 Standard: Windows 7 Professional 64-bit; TextMaker Mobile for Android: Nexus 7 2nd gen.
cyberdiva
Post by cyberdiva » Tue Sep 15, 2015 9:27 pm
I also wrote to Microsoft about this problem (since for me it involved Microsoft Security Essentials). It was suggested that I "contact the developer of SoftMaker office and provide this link": https://www.microsoft.com/security/port ... urces.aspx
Post by sven-l » Wed Sep 16, 2015 8:44 am
cyberdiva wrote:I also wrote to Microsoft about this problem (since for me it involved Microsoft Security Essentials). It was suggested that I "contact the developer of SoftMaker office and provide this link": https://www.microsoft.com/security/port ... urces.aspx
I filled out the Developer contact form under the link you provided. I hope it helps to add our service packs to the white list of Microsoft Security Essentials.
cyberdiva
Post by cyberdiva » Wed Sep 16, 2015 2:02 pm
Thanks very much, Sven. I hope that will prevent future false positives.
