Images resolution issue
Questions and answers about Presentations HD for Android
Alessio
Post by Alessio » Tue Mar 24, 2020 11:21 am
When I insert an image or an object in my slide using Presentation HD the resolution of the images drop sensibly from the original files.
Even the resolution of lines and shapes created with the app are very low.
How can I fix this?
How can I add to my presentation High resolution images and objects?
Re: Images resolution issue
Post by miguel-c » Fri Mar 27, 2020 12:29 pm
I wasn't able to reproduce the issue you describe...
Have you tried saving the Presentations file as prdx or pptx and then opening it in your computer?
Are they low res at the PC too?
Return to “Presentations HD”
