Timing transition
Questions and answers about Presentations HD for Android
sundaydiver
Timing transition
Post by sundaydiver » Fri Jan 22, 2016 1:25 pm
1) I made a slide show incl. timing in Windows Power Point 2007
2) Saved and copied the slide show to my Samsung Android (4.1.2) phone in .pptx as well as .ppsx
3) When I open the presentation on the phone, I note in the slide menu that the timing also has been copied correctly
4) In both cases the timing gets out of sync when presentation is played on the phone
Please inform:
Alt. a) How to copy the presentation so that correct sync is maintained during play on the phone
Alt. b) How to adjust the timing subsequently on the phone
Jim-J
Re: Timing transition
Post by Jim-J » Fri Jan 22, 2016 4:31 pm
Hello,
can you send us the presentation file please?
You can also send it to forum(at)softmaker.de. Please don't forget to add your forum name and copy the link of this thread into the email.
Thank you.
Jim J.
Jim-J
Post by Jim-J » Thu Jan 28, 2016 12:09 pm
Hello,
I received your sample file.
I checked this issue with a Samsung Note 3 Android 5.0
The transition timing worked properly. I checked this with a stopwatch. See the sceenshot. I stopped the presentation at slide 7. That's why it's less than 30 seconds.
Can you check the timing with a stopwatch http://stoppuhr-online.chronme.com/?
Can you also send us the sminfo.txt (Help->About->Write Systeminformation).
Jim J.
Return to “Presentations HD”
