Locking Row Height
Questions and answers about PlanMaker HD for Android
userjeff
Locking Row Height
Post by userjeff » Tue Jan 05, 2021 11:47 pm
II just switched from Excel to Plan Maker for my job because of stability and performance issues with Excel on our Android tablet. Plan Maker runs much smoother and allows multiple sheets opened at once. It also feels like a more serious workhorse application.
But I'm wondering if there is a way to lock the row height for a sheet?
The problem I'm having is that when I go select a row, for example to highlight it with a different color, the row height often changes. After I'm done with the spreadsheet it looks kindof sloppy because a bunch of row heights have changed slightly. Any solutions to this are very much appreciated. If not by locking the row height, maybe there is a different way to select and highlight a row that I'm not aware of that doesnt risk the row height shifting.
Re: Locking Row Height
Post by miguel-c » Wed Jan 06, 2021 8:29 pm
There's no way to lock the row height that I'm aware.
However, if you double-tap on the row number, it will automatically adjust it's height to fit its contents
You can also go to the menu Table > Row > Height and set an height there.
Return to “PlanMaker HD”
