ROWS can generate false circular reference warning [UPDATED]
Post your questions, bug reports and suggestions here for PlanMaker HD for Android.
bsbd
Post by bsbd » Mon Sep 28, 2015 7:45 pm
In PlanMaker HD, any formula containing the "ROWS" function will generate a false circular reference warning if the specified array value includes the current cell. Since it's not really a circular reference, I don't receive these warnings in Excel.
PlanMaker still correctly evaluates any formula containing ROWS, but the warnings are a nuisance.
I'll send a very simple example file.
-bsbd
bsbd
Re: ROWS can generate false circular reference warning [UPDATED]
Post by bsbd » Tue Sep 29, 2015 5:25 pm
I discovered that this is also an issue with three other similar functions, ROW, COLUMN, and COLUMNS.
The good news is that I received a reply from SoftMaker support with a hotfix, but it was only for the Windows version which does me no good. They did say that the fix will be in the next updates for Android.
Post by sven-l » Wed Sep 30, 2015 11:59 am
Please wait for the next service pack and try again as soon as it is available . It should solve these issues.
Return to “PlanMaker HD”
