Problem with .xls files created by planmaker
Questions and answers about PlanMaker HD for Android
sdzang
Post by sdzang » Tue Nov 25, 2014 9:07 pm
There seems to be a problem with saving a file as .xls. I can duplicate the problem by starting a new file in Planmaker for android obtained from Google Play store November 2014 (trial version),
then type anything into one cell,
then save as an .xls file,
then copy to windows 7 based PC,
then try to open in excel 2010 for windows.
Excel opens the file but places it in protected view because it detects a problem with the file.
Other software that is designed to read .xls files also has a problem with the file generated by planmaker.
Saving as an .xlsx file seems to work OK
Is this a problem with the trial version or a known bug?
Jim-J
Re: Problem with .xls files created by planmaker
Post by Jim-J » Wed Nov 26, 2014 5:52 pm
sdzang wrote:There seems to be a problem with saving a file as .xls. I can duplicate the problem by starting a new file in Planmaker for android obtained from Google Play store November 2014 (trial version),
Hello,
This is reproducible for me. I reported this to our developers.
Thank you.
Jim J.
Jim-J
Post by Jim-J » Tue Jun 16, 2015 1:26 pm
Hello,
The developers solved the problem. The fix will be released with the next service pack.
Jim J.
Return to “PlanMaker HD”
