Screen dimming on Samsung Tablet with mouse and Keyboard
Questions and answers about TextMaker HD for Android
Gizea
Post by Gizea » Thu Aug 13, 2020 7:34 pm
Hi...
I'm wondering if there is anyway to stop the screen from constantly dimming on a Tablet when using TextMaker HD.
For example: When I hit the delete key it dims. When I click on the white are it lightens backup.
I haven't been able to find anything in the Options for screen dimming at all and I have a ton of pages to edit. It's very irritating.
Thanks.. Any advice is much appreciated.
Re: Screen dimming on Samsung Tablet with mouse and Keyboard
Post by SuperTech » Fri Aug 14, 2020 1:01 am
That's actually a feature of your Operating System (Android). Please disable "Adaptive brightness" and then try again:
1. Go to "Settings".
2. Tap "Display".
3. Tap the switch to deactivate "Adaptive brightness".
4. Slide the bar to the right to increase the screen brightness.
You can also try to increase your Tablet's Screen timeout or disable Power saving mode which are again android's features.
Return to “TextMaker HD”
