TextMaker HD crashes when opening .docx or .doc files from Dropbox
Post your questions, bug reports and suggestions here for TextMaker HD for Android.
alisonnic
Post by alisonnic » Mon Apr 02, 2018 5:35 pm
Update: I have isolated this problem to the interface between TextMaker HD and Dropbox. Other apps do not have this issue. See Reply below the OP for more info.
I've been looking for a word processing app for my Android device that will do what I call "electronic markup." This means having the ability to track changes, and to add and edit comments in documents created by myself and friends. TextMaker would be perfect for this, except that it crashes whenever I open a document.
I use Word on my PC, and I'd like to have something that can fill in for it when I'm on the go. I use mostly .docx format, although I do have some older .doc files. All the documents are stored in Dropbox, and my Android device, an Asus Chromebook Flip, has Dropbox (and Android) enabled.
The Flip is a great device to take with me to the library or meetings or wherever. But I need a way to edit documents on it, including tracking changes and inserting comments, and showing changes and comments I'd already made in Word on my PC.
I tried almost a dozen apps before trying TextMaker HD Basic. None of them had all the features I needed. I was delighted when I found this app because it does have everything. Comments, track changes, next/previous comment, next/previous change. Awesome! I bought the upgrade within minutes of trying the app.
The only problem was that on my Flip, which has a 10" screen, the UI was huge. The menu and status bars took up a third of the screen, leaving me relatively little space to read and edit my documents. So I tried resizing the UI (Tools > Options > Appearance > User interface size). The Small controls size with text size at about 75%, plus Large Icons selected on the Appearance pane, is just about perfect.
But now whenever I open a .docx or .doc file from Dropbox, TextMaker crashes immediately. I've tried many things, and at one point when I set the UI size and icon size back to default, I was able to open my documents. But now even that doesn't work. Even with the default settings, TaskMaker crashes as soon as I open a document.
I'm so disappointed! I'd spent many hours research all those apps, and TextMaker was the last one on my list. I thought this was the perfect solution for me. But it's broken. #-o :cry:
Can anyone suggest a fix or at least a workaround for this problem?
Thanks!
Alison
alisonnic
Re: TextMaker HD crashes when opening .docx or .doc files
Post by alisonnic » Tue Apr 03, 2018 8:32 pm
I have found a workaround: if I copy the document from Dropbox to the local Download folder on the Flip, then I can open, edit, and save it without TextMaker HD crashing.
So it appears that this issue is associated with TextMaker HD opening files directly from Dropbox on a Chromebook.
Is there any way to report a bug, other than posting in this forum?
Note: I am able to open .docx and .doc files from a number of other apps on this machine without a problem. The issue of crashing when opening files from Dropbox is clearly associated with TextMaker.
I also tried uninstalling my antivirus, Avast, but that didn't help. TextMaker still crashes when opening a .docx file from Dropbox, but can open a copy of that file from the local Download folder.
Post by sven-l » Tue Apr 10, 2018 10:07 am
Yes, via the support form:
http://www.softmaker.com/en/support-assistant/view/form
alisonnic
Re: TextMaker HD crashes when opening .docx or .doc files from Dropbox
Post by alisonnic » Thu Apr 19, 2018 7:43 pm
Thanks! I've posted a bug report. Hopefully the developers can find a resolution.
alisonnic
Post by alisonnic » Mon May 07, 2018 2:37 pm
Here is Softmaker’s response to my bug report:
Dear valued customer,
TextMaker HD on Chromebook OS isn't officially supported by our company, so problems related to our software on this operating system should be solved by yourself.
We don't provide any support in such cases.
Best regards
alisonnic
Post by alisonnic » Wed May 23, 2018 4:14 pm
Okay, I've taken some time to cool down from what felt like a poke in the eye with a sharp stick. I've found another product that does almost everything TextMaker does, and does it very well on my Chromebook.
However, I would suggest that SoftMaker is compromising the potential growth of the company by choosing not to support their products on Chromebooks.
Chromebook sales have far outstripped sales of competing products:
https://techcrunch.com/2017/04/27/as-ch ... ght-back/
According to the above article, two million Chromebooks were sold in the first quarter of 2015, and Chromebooks have taken 58% of the school market in the US, compared with 22% for Windows and 19% for MacOS and iOS combined.
Now take into consideration the fact that engaging children at an early age offers the possibility of instilling a lifetime loyalty to a product and company.
Is it wise, I would ask the SoftMaker Team, to ignore such an enormous market for your products?
Return to “TextMaker HD”
