Sent file loses password protection
Questions and answers about TextMaker HD for Android
PeteCC
Post by PeteCC » Sat Mar 10, 2018 12:04 pm
When you 'send' (share) a password protected (docx) file it loses its password protection. Is there some reason for this or is it a bug?
Re: Sent file loses password protection
Post by sven-l » Tue Mar 20, 2018 5:09 pm
Which program is used to open the docx file? TextMakerHD seems to have no problems with password protected docx files.
Here is what I did:
1. I opened TextMakerHD on ym Android phone (Android 7)
2. Then I typed something
3. Now I set a read password
4. I saved the file on .docx file format
5. I re-started TextMakerHD and opened the docx file
=> It asked for the password. When I entered the correct password the file opened properly.
PeteCC
Post by PeteCC » Tue Mar 20, 2018 8:55 pm
Sorry, I said 'sent' or shared, not saved.
Do as you have done - then open the file with TextMakerHD, provide the password. Then select File>Send... then select "Word 2007-2013 document" and a destination app - I've tried both a cloud storage app (Sync.com) and a file explorer (X-plore) - the file will be provided to the target application without password protection (Android 7.1.1).
Post by sven-l » Wed Mar 21, 2018 8:07 am
Ok, I can now confirm this issue. It happens also with tmd files sent to Google Drive. I will inform the developers.
Return to “TextMaker HD”
