Cannot Access Data Within Tables
Questions and answers about TextMaker HD for Android
AJ_
Post by AJ_ » Mon Jun 26, 2017 3:52 am
Every time I try to access data within my tables, Textmaker HD selects the entire document. There is no way to deselect the entire document or enter a cell to edit my text. All I can do is view the document. I have identified issue after issue with this app and Planmaker HD. Are you aggressively working these issues? Both of these apps are nearly completely dysfunctional. I am having to do all of your debugging for you? Can I ever expect you to fix these issues?
Kasey01
Re: Cannot Access Data Within Tables
Post by Kasey01 » Thu May 28, 2020 7:53 am
When you link to a table in an Access database, Access creates a new table, called a linked table, which maintains a link to the source records and fields. Any changes you make to the data in the source database are reflected in the linked table in the destination database, and vice versa.
Return to “TextMaker HD”
