When I installed SoftMaker HD on my Samsung tablet, it installed on the internal storage. That's getting filled up. I have a 64 GB microSD card installed, with almost nothing on it. Is it possible to move the Softmaker HD app from the internal storage to the SD card (and will the fonts move with it)? If I can't move it -- can I uninstall it, and then reinstall it so that it goes to the SD card?
If I have to reinstall it -- how can I make certain that it goes to the SD card?
Installation location
Re: Installation location
No, this is generally impossible in Android.
get a bigger sd card,format it,move everything from the old card to the new card...
On rooted devices you can grant access to external sd card even with third party apps...anyway the more secure way is to get a bigger card...250G is the minimum you should use
