Cryptomator Support?
General questions and answers about SoftMaker Office HD for Android. Don't post application-specific questions here, but in the appropriate subforum.
AJ_
Post by AJ_ » Sun Feb 11, 2018 3:36 am
Would it be possible for you to work with Cryptomator to enable write capability when using Softmaker products? Currently only read capability is provided. When files are saved Softmaker pretends to save the updates to files but does not actually save the changes. The Cryptomator app provides 256 AES on the fly encryption for cloud based files/folders, but it is basically useless since Softmaker will not save the changes to Softmaker files.
The Cryptomator/Softmaker combination works flawlessly on a Windows PC but fails miserably using Cryptomator/Softmaker HD products on Android. The different OS architecture is obviously the issue but is there anything you can do to resolve?
The BoxCryptor (another on the fly encryption product)/Softmaker HD combination works flawlessly on android, but the annual subscription for BoxCryptor is substantial. Its cost makes it not worth considering for long term use.
Re: Cryptomator Support?
Post by sven-l » Mon Feb 19, 2018 2:26 pm
I will refer your suggestion to support Cryptomator to our product management.
Return to “SoftMaker Office HD for Android (General)”
