Printing Softmaker (.tmd et al) files from smartphone
Post here those questions, bug reports and suggestions for SoftMaker HD for Android that do not fit in any of the application-specific subforums.
david12
Post by david12 » Fri Feb 10, 2017 10:34 pm
I use Brother iPrint&Scan app to print from my smartphone. It will print .pdf and .docx files, but not .tmd (nor, presumably, other SoftMaker file types.) Is there a smartphone printing solution that will print SoftMaker files like .tmd? Thanks.
Re: Printing Softmaker (.tmd et al) files from smartphone
Post by sven-l » Mon Feb 13, 2017 10:28 am
When the Brother iPrint&Scan app does not support SoftMaker's file types, you have to export the file into an supported format like PDF or an MS Office file format.
Return to “SoftMaker Office HD for Android (General)”
