Some animations on Auto-Rewind
Post your questions, bug reports and suggestions here for Presentations Mobile for Android.
Porkypete58
Post by Porkypete58 » Wed Jul 02, 2014 3:50 pm
Take a look at this file:
http://1drv.ms/1iXybF2
In Powerpoint Slide Show (Windows 7 / Office 2010)
There is a blue "+" symbol at the left of the screen
After a short delay the "+" rotates 45 degrees clockwise, to become an "X"
After another short delay the "X" moves to the right (to about the middle of the screen)
Anoher short delay and the "X" gradually fades away, leaving a blank screen
In the Android app Trial version downloaded from Google Playstore - running the same file.
Suddenly the "X" reverts to a "+" and moves to the right (to about the middle of the screen)
Then suddenly the "+" jumps back to the left side of the screen and gradually fades.
Then suddenly the "+" re-appears in the middle of the screen and stays.
In Powerpoint, in the Animation pane, if you select an animation effect, under the timing tab, there is a checkbox "Rewind when done playing"
It seems to me that Softmaker is automatically selecting this checkbox because most of what I described for Softmaker can be reproduced in Powerpoint by checking that box.
Please can you fix it so that the Softmaker Presentations app shows the same on the screen as a Powerpoint slideshow.
Then I can buy the app, (and give it 5 stars on the PlayStore)
Re: Some animations on Auto-Rewind
Post by sven-l » Wed Jul 02, 2014 4:30 pm
Thank you for the sample file and bug report. I can reproduce that problem even with the Windows version of Presentations and referred it to the developers. I will inform you here as soon as we have a bugfix available.
Porkypete58
Post by Porkypete58 » Sun Aug 31, 2014 10:09 pm
Just received latest Beta
The problem is still not solved.
Over a year now since I first reported via feedback on Google Play Stote
Post by sven-l » Fri Sep 12, 2014 10:55 am
I informed the developers that the problem is still not solved. Thank you!
Return to “Presentations Mobile for Android”
