slideshow
Post your questions, bug reports and suggestions here for Presentations Mobile for Android.
marian
slideshow
Post by marian » Mon Feb 10, 2014 11:24 am
in slideshow mode touching the screen will go to the next slide. Going back one slide requires to go throgh the menu bar.
Will it be possible to move forward and backward by a forward or backward motion on the screen?
Marian
Re: slideshow
Post by sven-l » Tue Feb 11, 2014 1:28 pm
You can move back to the previous slide if you fling (use the finger to drag from one slide to the next).
marian
Re: slideshow
Post by marian » Sun Feb 16, 2014 11:57 am
Sven, thanks for your answer.
I've tried to fling left, right up and down with the same result, going to the next slide.
Re: slideshow
Post by sven-l » Mon Feb 17, 2014 1:38 pm
Which version are you currently using (Tools=>About)?
marian
Re: slideshow
Post by marian » Thu Feb 20, 2014 8:45 am
Android version 4.2.2
Presentations Mobile Version 1.0
Re: slideshow
Post by sven-l » Thu Feb 20, 2014 2:06 pm
Are you sure? Presentations should have the Revision 685. Please have a look in Tools=>About. Thank you!
marian
Re: slideshow
Post by marian » Fri Feb 21, 2014 9:31 am
Sorry, I can't find that information. Maybe I should simply delete the app and download the actual version.
Marian
marian
Re: slideshow
Post by marian » Fri Mar 07, 2014 3:36 pm
Sorry, I can't find that Revision information. Maybe I should simply delete the app and download the actual version.
Would that work?
Marian
Re: slideshow
Post by sven-l » Fri Mar 07, 2014 4:35 pm
The revision information is in the main menu in Tools=>About. If you cannot find it, you can uninstall it, download and install the .apk file again just to be sure to work with the newest available version.
Return to “Presentations Mobile for Android”
